Passenger side header
Installing passenger side header is a bitch, it seems that the collector is getting the control arm... how can we get this to fit in WITHOUT lifting the motor?
What kind of header is it, a long tube? When trying to get my Pacesetter long tube in thru the passenger side, I found myself spending quite awhile playing with the angles to get it just right to snake in in there. Be careful and don't force it because if you have a coated header, you'll scratch it up real quick. If that doesn't work, then yes, you may have to end up unbolting a motor mount and raising the motor a tad.
Jul 4, 2005 05:00 PM
