parts list for opti conversion???
Old May 3, 2003 | 02:56 PM
notstock4long's Avatar
Okay, I wrecked the engine in my 94, but found a 95 that I am going to buy. What parts do I need since this engine requires a venteds opti. I know there have been posts on doing this to a pre-95 car, but I want to make sure I don't get any parts I don't need. Do I ned different wiring harnesses or anything? Thanks.
Old May 3, 2003 | 03:09 PM
You will need the 95 electrical harness that is mentioned here:
http://para.noid.org/~muttvette/opti.html . Don't know what you are getting with the new engine, so you may some of the other things, as well.
Old May 4, 2003 | 11:08 AM
Hey shoebox, any idea how much those parts will cost, and where I can get them? The engine is missing the opti and plugs and wires, so I'm not sure if it needs all those other harnesses. Since he took that opti off and put it on another 95 engine, I am sure it won't need the timing cover and gaskets. I a mostly concerned about the two harnesses and vacumm fitting. Would the dealer be the best place to get those?
Old May 4, 2003 | 11:22 AM
Yes, get them at the dealer. Get all your GM parts from:
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
or
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
The electrical harness is not real cheap (~$70 wholesale). The vacuum harness is ~$12.
Old May 4, 2003 | 01:58 PM
96 WS6's Avatar
DYNASPARK!!!!!!
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
