part-throttle hesitation
Old Jun 26, 2003 | 06:10 PM
Cmr0z28's Avatar
if im cruising around the neighbor hood at slow speeds accelerating at light throttle, the car will hesitate until it gets to the next gear, shoot forward when the gear changes and begin to hesitate again. once i'm above like 30mph it goes away, and only does it in 1st and 2nd gear. any ideas? plugs/wires were just changed about 6 or 7 months ago
Old Jun 26, 2003 | 07:40 PM
Cmr0z28's Avatar
ttft
Old Jun 26, 2003 | 08:23 PM
slopokrodrigez's Avatar
Probably EGR, you can do a few things to check it. One is push the diaphragm by hand and feel it if is rough. Maybe sticking. You can pull it off and clean it. That usually helps. See if it is sticking while it's off. The valve it self could be leaking. You can also try disconnecting the vac line and plugging it and see how it runs. More than likely this will fix your problem.
Old Jun 27, 2003 | 11:04 AM
Cmr0z28's Avatar
ok thanks, any other suggestions anyone?
Old Jun 27, 2003 | 11:06 AM
Scream And Fly's Avatar
Check the TPS.
Greg
Old Jun 27, 2003 | 11:07 AM
G's Z28-LT1's Avatar
I second the egr.
Old Jun 28, 2003 | 01:24 AM
Lt1t56's Avatar
I had the same problem for about a year now, bought a scanmaster to monitor the situation, now it wont act up. Guess it fixed itself, but one thing that seemed to help was cleaning the MAP sensor with carb cleaner.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
