Part # for Thicker intake gaskets?
Old Dec 5, 2005 | 01:39 PM
Camaro97USAF's Avatar
Does this even exist? I have new Stock GM and oil seeps past the bottom, so the car smokes. Anyone heard of a thicker gasket I can use? With the heads block and intake all milled, the intake doesn't seal right. Any ideas?
Old Dec 5, 2005 | 09:59 PM
Re: Part # for Thicker intake gaskets?
No one? Bueller? Bueller? Someone has to know some info.
Old Dec 6, 2005 | 02:06 AM
hallbilly's Avatar
is it leaking between the intake and the heads? or the front and rear of the motor? If it is just the front and rear of the motor I would just clean the old gunk off and put new RTV sealant or whatever it is there. You shouldn't need "thicker" intake gaskets if everything is stock
shouldnt... good luck though
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
