part #'s needed to install 987's on stock heads
Old Apr 6, 2009 | 10:20 AM
mightymouse383's Avatar
HELP!!! need part numbers for spring retainers and valve locks to install comp 987's on to a set of stock heads.
Old Apr 6, 2009 | 06:24 PM
This sucks!!!!! Nobody is running comp 987"s on an lt1, give me a @&#*ing break!!!!!!!!!! what the hell do i have to do to get a reply talk about turbos and superchargers!!!!!!!!!!! Is the question the technical to get a answer!!!!!!!!! Summit gives me one part # while jeggs gives me another!!! I thought somebody on this board would know!!!!!!
Old Apr 6, 2009 | 06:26 PM
mdacton's Avatar
you got a link crybaby?
I'm not looking upo your specs....
if they are bigger than 1.2600" then seats need to be cut locators etc. If you have to even ask then your best best is to take the stuff to a machine shop and let them set them up
Old Apr 6, 2009 | 09:06 PM
lt1srule's Avatar
just spray a little ky on there and they slip right in -yes sir.
Old Apr 6, 2009 | 09:32 PM
RamAir95TA's Avatar
Maybe if you waited a little longer than 8 hours someone might respond.
And if you weren't such a baby, people would be more inclined to help you.
Old Apr 7, 2009 | 04:16 PM
MTBSully's Avatar
Comp Cams 1.430" Diameter Double Valve Springs
Comp Cams 10 Degree Titanium Retainers for Comp #987 Valvespring
i literally typed those two things into google and the two things you need will come right up
Old Apr 9, 2009 | 10:17 AM
Sorry guys for going off of the deep end, I just want to get everything installed so i can drive my car. I get frustrated when everybody keeps telling me different things and i don't know what to go with. I have retainers, springs, locators and just need to order the locks. I did go with the steel retainers for a 10 degree lock.
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
CobraEatr
Jul 23, 2002 06:32 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
