Part Numbers
Old Feb 26, 2004 | 09:18 AM
AlmostfastLT1's Avatar
Part Numbers
I want to get a part number for an lt1 degreeable doulbe roller timing chain. Using csi electric water pump and 95+ vented opti.
Old Feb 26, 2004 | 09:39 AM
ttt
Old Feb 26, 2004 | 09:50 AM
Just be aware that if you change the cam's relationship to the crank, it will throw the spark timing off. Alterations to the PCM programming will be needed.
Old Feb 26, 2004 | 10:14 AM
Grease's Avatar
Cloyes timing chain from Summit Racing p/n CLO-9-3145. And like Shoebox said, if you advance your cam you are also advancing your spark without the PCM knowing about it.
Old Feb 26, 2004 | 12:15 PM
yes I am aware, I am getting the LT4 Knock module and tunning.
Thanks Mark Tisdale
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
