parking/emergency brake
Old Mar 11, 2004 | 02:00 PM
Coolformula's Avatar
I have not drove my car in a week. Went out there moved it in the driveway. And I pull up the parking brake and the brake light dont come on?? It did last week. It comes on at startup, so where is the sensor at??
Question 2.
I think I need alignment( but i cant do wiht my aftermarkert wheels) I checked my tires. Front driver is fine but thr passenger is worn very bad on the inside(side closeest to the body). I guess I will have to put stock tires back on and go get it aligned.
Old Mar 11, 2004 | 06:50 PM
961le's Avatar
under the console, there is a clip that snaps onto the e brake mount. it is one wire orange i think. check the connection.
Old Mar 11, 2004 | 11:40 PM
OBE1 95Z28's Avatar
Why can't it be aligned with aftermarket wheels? I'm running 17 X 9.5 and my alignment shop didn't have any issues.
Old Mar 11, 2004 | 11:57 PM
Your alignment needs to be made with the wheels/tires you are running for it to be correct.
Old Mar 12, 2004 | 11:58 AM
Well the eagle wheels have no "lip" so every shop I go too can not align the car. They say they cant hook on to my wheels.
So where at under the console under where the e brake is??
thanks guys
Old Mar 12, 2004 | 02:08 PM
greensmoke's Avatar
Have you tried a reputable alignment shop? They should be able to align your car regardless of what kind of wheels you have. If not, and your stock wheel/tire combination height isn't the same, the alignment will be off, and you'll be right back where you started from. I would try to find a shop that specializes in vehicle alignment, not just a tire shop.
Old Mar 12, 2004 | 05:23 PM
961le's Avatar
you can probobly see it if you remove the shifter boot. it is just one wire that connects to a switch at the front of the ebrake mount.
Old Mar 12, 2004 | 09:19 PM
well now my ebrake light is working i did nothing. I wenr to sears a locally place and called a alignment shop still nobody can do it. im just going to get some zr1's ...
Old Mar 12, 2004 | 09:40 PM
dkeers's Avatar
thanks guys
I had eagle 077's on my 95 v6 a few years ago and I was told I couldn't get the vehicle aligned with them on.
I'm sure it's better to align with the wheels you are going to use but I would think they could get close with the stock wheels.
Old Mar 12, 2004 | 10:19 PM
ROADRAGE's Avatar
Same thing i had. no one could do the 077's Huge PITA
Old Mar 13, 2004 | 08:18 PM
Now stupid 077's look like they would made them to align thats crazy. So i guess i will just get some zr1s polished....
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
