difference between 1.7RR BBC and 1.7RR SBC??
Old Mar 12, 2004 | 08:56 PM
scyzoryk's Avatar
What is the difference between 1.7RR from Big Block and 1.7RR from Small Block? Are those interchangeable???
Old Mar 12, 2004 | 09:01 PM
95_LT1_6SPD's Avatar
I wouldn't imagine they were interchangable, and the sbc ones are probably cheaper anyways.
Old Mar 12, 2004 | 09:44 PM
scyzoryk's Avatar
I can have Big block version for $160...and all I found for SBC was over $250..
Old Mar 12, 2004 | 09:58 PM
Spinner's Avatar
I'm sure the SBC rockers are much physically smaller
Old Mar 13, 2004 | 07:52 PM
arnie's Avatar
Correct! Ratio is the same, but the physical length is greater, for the BBC rocker.
Which means, the longer distance, from the pivot to the valve tip, will improve the geometry, of the rocker, through it's travel.
Old Mar 13, 2004 | 08:20 PM
1984camaroz28's Avatar
BBC are alot bigger. bigger push rod bigger head stud and the just bigger . they will not work
G-BODYT56
Jan 14, 2022 11:14 PM
WobblySausage
Oct 7, 2015 02:44 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
