panhard bar adjustments?
Old Jul 25, 2003 | 02:08 PM
chevy1963's Avatar
I just installed the new BMR adjustable panhard bar how do I get can I tell if the rearend is lined up instead of using the string and wieght at the end. My car is lowered and when ever i hit any bumps in the road the the left rear tire hits the inner lip of the quater panel.
Old Jul 25, 2003 | 02:10 PM
chevy1963's Avatar
wow, is that tuff to read, sorry guys hope you understand my question.
Old Jul 25, 2003 | 02:12 PM
You need to measure the clearance between the inside edge of the tire, and something fixed to the chassis, like the subframe. That distance has to be the same on both sides.
Old Jul 25, 2003 | 02:15 PM
chevy1963's Avatar
hey thanks your answers your always on top of my questions. This is my first F-body, I'm used to building 50's and 60's cars.
Old Jul 25, 2003 | 02:42 PM
Yehhhh, me too..... except all my 60's cars I bought new....
Old Jul 25, 2003 | 03:36 PM
94formulabz's Avatar
I used a 2x4, layed it accross the center of the wheel and lined it up with the same spot on the body since it's curved.
".......I selected the adjustable model so i could recenter my rear axle. This adjustability is only neccesary on lowered cars, but all fbodys could benefit from the increased stiffness. Centering the axle presented a new problem however. Since I had effectively shortened the panhard rod to move the axle right, the right rear tire now rubbed the fender under full compression. Because it was Sunday afternoon and I was due to return to school I used an adjustable wrench to curve the inner fender lip up giving it a little more clearance. This wasn't quite enough though. Thanks to a fbody.com user I found out that SLP sells 15mm spacers for your bumpstops to keep the wheels off the fenders. I'm not too happy with my limited rear suspension travel now, but at least I'm not buying new tires weekly. "
I just quoted myself, haha, copied and pasted from my site.
good luck,
brent
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
