Painting rims need HELP!!!!!!
Old Jan 23, 2003 | 09:21 PM
KillinFormula's Avatar
(Post #1)
Painting rims????
ok well i am going to paint my rims black, they are the 16 inch 5 spoke stock wheels.
here is how i am going to do them:
take the wheel off
clean it
tape the tire up
scrap the rims with steel wool to scratch it
put 7 layers of black gloss on it
then 7 layers on clear coat on it
so how will it look
do any of you have a pic of someone who has painted their rims?
PLease help need pics too!!!!!!!
thanks guys
Old Jan 23, 2003 | 09:26 PM
1994TransAm's Avatar
hey there,
i've paint my rims before and you should TAKE THE TIRE OFF FIRST!!
most tire shops like discount tire do it for free.
you must take the rim, and sand it down so you can have surface for the paint to stick to, wash and clean the rim after to get rid of dust. then a couple coats of paint 7 is too much IMO. 3 or 4 is good and 4 coats of clear will be more than enough.
just remembe to go slow, and dont make the paint uneven!!!
Old Jan 23, 2003 | 09:32 PM
how did they look, did they shine, also do you have any pics?
Old Jan 23, 2003 | 09:34 PM
WS6JEM's Avatar
Remove the tires, then take the rims to a shop that does sandblasting and have them beadblasted. Otherwise the paint wont stick.
2 coats black epoxy primer (this also helps adhesion!)
2 coats black paint
2-3 coats clearcoat
Old Jan 23, 2003 | 09:38 PM
dont have money for sand blast, and i am going to use an *** load of sand paper and steel wool and put some nice grooves in them.
vut keep the replies coming i want a lot of viws, also NEED PIC!!!!!
thanks guys/girls
Braden
Old Jan 23, 2003 | 09:40 PM
dunkchamp55's Avatar
painted rims
i just painted my buddies ws6 rims and found they came out really nice, i sanded them down pretty rough, 2 coats of primer, 3 coats paint 2 coats of clear and let em sit for a while i didnt take the tires off no need to do that your not gonna be dumpin paint on em just spray in nice even layers(passes) ill have pics up this weekend
any other ?'s let me know
ryan
Old Jan 23, 2003 | 11:04 PM
n2oTransAmLT1's Avatar
My wheels are being painted black as we speak by a reputable paint shop. It is only $50 to get each wheels tires removed, wheel sanded, primered, painted and clearcoted, tire put back on and balanced. Once I found out how cheap it was, I just decided it wasnt worth the hassle to try to paint it myself. The paint alone and materials will cost at least half that. Its being painted to match the color of my car...stock gm black, whatever you want to call it. Guess there will be a bunch of us out this summer with black wheels. Also, the painter told me that its fairly difficult to get paint to stick to the powdercoated silver wheels, but is apparently fixed with a special primer. Good luck with the wheels. Ill post some pics of mine when thier done.
Well i am deffinetly painting my rims!!!!
Old Jan 24, 2003 | 08:13 AM
max929's Avatar
http://www.bfranker.badz28.com/appearance/
Old Jan 24, 2003 | 08:50 AM
WS6JEM's Avatar
Price atomotive grade sandpaper and sandblasting then make your decision. If you dont want to sand blast use 320 grit sandpaper, dry, red scuffpad with ppg final scuff and water. Do not use steel wool.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
CARiD
Sep 30, 2015 05:44 AM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
