paint for lifter valley
Old Nov 28, 2005 | 06:57 PM
Fbody1's Avatar
is there any paint that I can put on at home for the lifter valley to make the oil drain faster to the pan?
Old Nov 28, 2005 | 07:36 PM
1racerdude's Avatar
Re: paint for lifter valley
Painting the valley is not a good idea. Unless done exactly correct it will peel off and get in the oiling system. The stuff ya see in books is Glyptol and it is used on electric motors and has to be baked in an oven.Nothing at Lowes or auto parts will stay on for very long.
Just use your die grinder and a rotary file to chamfer all the return holes and the bottom of the grooves or valleys in the lifter valley.Then use a stiff wire brush with your die grinder to smooth it out some.
There isn't generally a problem with oil return in a SBC.
Old Nov 28, 2005 | 07:40 PM
Fbody1's Avatar
thanks , also is there anything that I can coat the bottom of the intake with ( at home) that will help with heat soak?
Old Nov 28, 2005 | 07:44 PM
1racerdude's Avatar
Not that I know of,I sent mine off and had Caleco Coatings do it.
Old Nov 28, 2005 | 11:43 PM
TCAL95Z's Avatar
Does that coating really help much?
Old Nov 28, 2005 | 11:47 PM
1racerdude's Avatar
No not at all.
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
