Melling M55A - M155 oil pump difference?
Old Nov 28, 2005 | 10:23 AM
HungryT/A's Avatar
Hi guys,
I'm in the middle of buying a Canton Road Race oil pan.
They list the correct length pickup for the Melling M155 oil pump, but I have a brand new M55A unit. They do not list the pickup for this pump.
What are the differences between these two pumps? Can I use this pickup for my M55A?
Old Nov 28, 2005 | 12:47 PM
sssalah's Avatar
Re: Melling M55A - M155 oil pump difference?
The inlet diameter for the M155 is 3/4", if the M55A is the same diameter then it should work. It's not a bad idea to check the clearance between pan and screen nontheless.
Old Nov 28, 2005 | 06:37 PM
Lonnie Pavtis's Avatar
The M55 is a 5/8" pickup tube diameter. The M155 is a 3/4".
Around 94/95 they switched to the 3/4" pickup. I haven't got a definite changeover date & reports vary. All 95's I have built are 3/4".
Hope this helps.
Old Nov 29, 2005 | 03:52 AM
HungryT/A's Avatar
Thank you for the infos!
Do you know if there is a difference in dimensions (like height) between the two pumps?
Old Nov 29, 2005 | 06:01 AM
sssalah's Avatar
High volume pumps are taller. The pickup you need is for a standard volume with 5/8" tube. Canton part number 20-010.
Old Nov 29, 2005 | 06:07 AM
HungryT/A's Avatar
Thanks sssalah, that's what I was looking for! BTW, you've got a nice ss over there in the Bahrain!
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
