Paging Shoebox(Trans Pan question)
Do you happen to have a part # for the trans pan off a G.M. truck that uses the same bolt pattern,but has a drain plug built into it?I really want the same depth as the oem.Many thanks.
Originally posted by Mtrhds94Z
I have the Silverado pan p/n but it is deeper..
truck deep auto trans pan 24215535
~must use filter kit below~
filter kit for deep pan 24208576
