paging shoebox: I need part#
I just got on your site and looked up the MAF for 94-97 part# 25179711 but when I look it up on Gmpartsdirect the part# is 25008308 and its about a hundred dollars more than your part# number you have listed.
I need to order one ASAP but I'm unsure about the conflicting part numbers. Obviously the cheaper one sounds better but I just wanna make sure I'm getting the right one. Thanks
Hmm...when I look up 25179711 at gmpd it lists it and says it is $127.40. ??? Maybe you are seeing the old part number somewhere. They now list the LT1 and LS1 MAFs as the same for replacement and the price is cheaper than the old LT1 MAF.
the way I found the other part number was by using GMpartdirect's catalogue and looked under mass air meter for 95 camaro. I guess I'll buy the cheaper of the two and pray it works
Thanks shoebox
Thanks shoebox
cmsmith
Aug 27, 2015 06:37 PM
cmsmith
Aug 20, 2015 07:57 PM
