pacesetters long tube?
Old May 22, 2007 | 04:26 PM
cdog10's Avatar
I have a stock Z and am looking to open it up a bit will pacesetter long tubes do the job what other mods are needed with them to make the motor wake up alot better or will loud mouth cat backs be the way to go.
Old May 22, 2007 | 04:32 PM
95z28man's Avatar
Get a cold air intake, Pacesetter LT's and just about any popular cat back on the market. You can do a search to see what everyone has to say about catbacks rather than starting a new thread. Avoid Flowmaster. Pacesetters LT's are arguably the best bang for the buck, I have them myself and I love them. Might want to consider an off road y pipe from pacesetter as well if your looking to get the best result.
Old May 22, 2007 | 04:38 PM
2000GTP's Avatar
What year is your car? What style long tubes do you plan on going with, "race" or "emissions"?
Old May 22, 2007 | 05:48 PM
cdog10's Avatar
I have a 94 z looking at the pacesetter long tube then what? the y pipe going to the cat back here I can run what ever in michigan just can't be to loud or the 5.0 will be on my a@!
Old May 22, 2007 | 08:57 PM
95z28man's Avatar
If sound is an issue, your not gonna want long tubes with the loudmouth for sure. But if your going to get longtubes (best option as far as performance), the Pacesetters are fine. The y pipe is not 100% necessary, however if you want the best performance, get the y pipe as well. As far as anything after the y pipe, it's up to you. You can keep the stock system, but again, for best results, look into a good cat back system, Magnaflow, Borla, Dynomax, theres many different brands that all good. Avoid flowmasters though.
Old May 22, 2007 | 09:12 PM
KSSS's Avatar
while discussing this, is there any performace difference between the emissions legal ones and the non-emissions?
Old May 22, 2007 | 10:09 PM
2000GTP's Avatar
No.
Old May 22, 2007 | 10:11 PM
2000GTP's Avatar
You will need the Pacesetter y-pipe. That is the only y-pipe that will fit those headers unless you get one custom made, which will most likely cost substantially more.
Old May 22, 2007 | 11:13 PM
cdog10's Avatar
so I can go with the pacesetters with its y pipe and then the poor mans way to a hi flow muffler or a full cat back
Old May 23, 2007 | 02:59 AM
97Formy's Avatar
Yes
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
BLK1997Z28
May 7, 2015 03:01 PM
drptop70ss
May 4, 2015 08:22 PM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
