Pacesetter problems
Old Jun 19, 2005 | 10:00 PM
93z383's Avatar
Pacesetter problems
Just picked up car had the longtubes installed, and the things are contacting the bottom of the car in many places, I used there y pipe also. anyone had this problem is it a bad set or could it be something else? Motor mounts etc. it hitting under the driver and passenger floor board. Help
Old Jun 19, 2005 | 10:41 PM
Scream And Fly's Avatar
Re: Pacesetter problems
First place I would look is the motor mounts.
Old Jun 19, 2005 | 10:47 PM
Red on Red WS6's Avatar
That is a very common problem. Mine only does it when I make a turn so it does not bother me to bad.
Old Jun 20, 2005 | 07:45 AM
89385formula's Avatar
Yeah, motor mounts is what will cause that problem with the Pacesetter LT's, the only other spot I had an issue with after the motor mount swap was the PS heat shield, it hung down kinda far and would rub the header. I yanked that off and it doesn't rub anywhere now. Your gonna want to get that rubbing fixed because when you are driving it and it rubs the knock sensor will pick it up and retard your timing, causing you to be down on power.
Old Jun 20, 2005 | 10:37 PM
93z383's Avatar
Its hitting badly where the y pipe is 'noched" out already to clear the cross member fort the transmission, the heat shield is also just as stated above, not a hard fix but I have no clearance at that y pipe
Old Jun 20, 2005 | 10:56 PM
Alvin@pcmforless.com's Avatar
Be very careful, this can cause big time knock retard
Old Jun 22, 2005 | 10:04 AM
blackztpi's Avatar
what kind of motor mounts should i use if I'm goig to be installing pacesetters?
Old Jun 22, 2005 | 10:07 AM
Bawls's Avatar
When I was installing my pacesetters, I put in a set of Prothane poly motor mounts. You can find them on thunderracing for pretty cheap.
I feel ya on the y pipe touching the chassis, just takes a lot of patience and adjusting. I'm still working mine out.
Old Jun 22, 2005 | 10:25 AM
i went with the Energy suspension poly mounts when I did my LT's...they were pretty easy to do once I got the old shorty headers out really.I had no problems with the Y pipe hitting anything with the new motor mounts.
Kyle
drptop70ss
May 4, 2015 08:22 PM
racecarz28
Mar 30, 2015 09:55 PM
WildRidez
Mar 27, 2015 08:22 AM
Jazsun
Dec 29, 2014 12:14 PM
