Pacesetter LT Install
Old Aug 17, 2004 | 11:49 AM
Temple's Avatar
Question Pacesetter LT Install
Installing pass. side header and I notice most people have problem with the a/c line getting in the way...How do you go about bending this out of the way?...only thing holding me up to finishing the install.
Old Aug 17, 2004 | 12:22 PM
ram air camaro's Avatar
Re: Pacesetter LT Install
if the starter, and oil dip stick is off i don't think you should have a problem with intalling the header unless you ain't got the car high enough off ground.
make sure there's someone else helping you from the bottom or else it's almost impossible unles you got allot of patience and spend hour's.
Old Aug 17, 2004 | 12:53 PM
Temple's Avatar
I didn't have a problem installing the header...both sides went in easy from the top but the passenger side would not match up to the head because of the a/c line but I fixed it. Heated up the a/c line with a propane torch and tapped it with a rubber mallet...worked great...just hope I don't develop a a/c leak at that area.
Thanks for the advice though!!
Old Aug 17, 2004 | 01:21 PM
oh ! well at least you got by it, goodl luck! and dam is it loud driving to the muffler shop with open headers watch out for the cops. laterz
Nov 18, 2023 07:21 PM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
