Pacesetter LT
Re: Pacesetter LT
Most people would go with and aftermarket gasket other than the cheap paper like ones they give you. I just went ahead and used the ones that they supplied and I haven't had any problems..
Aaron
Aaron
Re: Pacesetter LT
How long have you been drivin it with the LT's and how many miles's?I plan on installing new heads so they will come back off in 2 months or so at the most.And did you use you stock plug wires and how hard are the plugs to change now? thhanks
Re: Pacesetter LT
The gaskets that come with are fine, but remember to retighten them several times the first few days. Once there is a leak, the gasket can get ruined pretty quickly. Mine finally got tight about the 5th re-tighten job.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
lol well i will tell ya all how it works out
