Pacesetter LT
Old Jan 26, 2005 | 05:21 PM
camarolover20's Avatar
Pacesetter LT
Should i use gasket maker on my pacesetter lt's or just use the gasket's i got with the car?
Old Jan 26, 2005 | 05:26 PM
94 CAMRO Z28's Avatar
Re: Pacesetter LT
Most people would go with and aftermarket gasket other than the cheap paper like ones they give you. I just went ahead and used the ones that they supplied and I haven't had any problems..
Aaron
Old Jan 26, 2005 | 05:32 PM
Re: Pacesetter LT
How long have you been drivin it with the LT's and how many miles's?I plan on installing new heads so they will come back off in 2 months or so at the most.And did you use you stock plug wires and how hard are the plugs to change now? thhanks
Old Jan 26, 2005 | 05:43 PM
chrism400's Avatar
Re: Pacesetter LT
The gaskets that come with are fine, but remember to retighten them several times the first few days. Once there is a leak, the gasket can get ruined pretty quickly. Mine finally got tight about the 5th re-tighten job.
Old Jan 26, 2005 | 05:52 PM
Re: Pacesetter LT
how tight should i make them i dont have a torque wrench
Old Jan 26, 2005 | 08:17 PM
chrism400's Avatar
Re: Pacesetter LT
Yea, I just used a boxed end wrench and hand tightened them pretty snug. You obviously don't want to strip the aluminum threads.
Old Jan 26, 2005 | 08:25 PM
Tom 97ss #25's Avatar
Re: Pacesetter LT
save yourself future headaches and leaks get a Percy Dead soft gaskets
760-66031 SB-Chevy D-PORT LT1
Jegs and summit carry them
Old Jan 26, 2005 | 09:41 PM
Re: Pacesetter LT
everything is closed and i wanna do it tonight lol well i will tell ya all how it works out
GREEN3112
Feb 10, 2019 09:19 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
