pacesetter long tubes
Old Aug 14, 2004 | 06:33 AM
Radd's Avatar
i have never done headers in my life and let me tell u if i never do another set on my car again it will be too soon.
after 2 days of waiting on some1 that said they would help me i went ***** to the walls on it.
finished the car yesturday and i am about to go get a y pipe made
my question is
my car is a 97 so i have like 3 or 4 o2s lost count
i put the 2 o2s in the headers in.
do i need to get o2 sims for the rest?
also after the install my asr is off always and my ABS INOP is on
what could i have done to cause that?
Old Aug 14, 2004 | 08:56 AM
Cmr0z28's Avatar
Re: pacesetter long tubes
You have four - 2 front and 2 rear. You can have the rear O2's programmed out via www.madz28.com or waste $100 on sims. ABS INOP has something to do with improper removal of the steering shaft....I forget exactly what it is. Also, check to make sure any plug wires aren't near the ABS sensor wires/unit.
Umm...what did you find so hard about it? I took my time, had no problems and they both slipped in from the bottom. Not hard, just time consuming.
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
BLK1997Z28
May 7, 2015 03:01 PM
drptop70ss
May 4, 2015 08:22 PM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
