Pacesetter headers,burning wire HELP!!
Old Sep 3, 2003 | 11:31 AM
whatsup's Avatar
Just installed headers a couple of days ago. You other guys with pacesetters...how are you keeping from burning #7 plug boot? I've gone through two since install. Can't keep it away. I'm running NGK TR55 plugs. Is there something shorter out there? Any help would be great!!!
Old Sep 3, 2003 | 11:35 AM
BlakeW5's Avatar
I don't make them for our cars, but accell makes spark plugs for headers that are alot shorter, maybe that would help you. You could also try OVC wires.
Old Sep 3, 2003 | 11:43 AM
whatsup's Avatar
This last time I did route it over the valve cover...to change angle direction on boot. Still touches header. I don't see much other alternitives other than a shorter plug or trying to beat in that primary tube to get more of a air gap.
Old Sep 3, 2003 | 11:32 PM
whatsup's Avatar
anybody else have any advice?
Old Sep 4, 2003 | 12:18 AM
whatsup's Avatar
Just found out Accel does make a shorty plug for our cars. It is called their "header plug" part# P526S.
Old Sep 4, 2003 | 03:04 AM
ltwonz's Avatar
I bought some taylor boot covers and haven't had a problem. I zip tied to the plug wire to make sure the stayed where I wanted them.
Old Sep 4, 2003 | 04:58 AM
magius231's Avatar
try using the stock aluminum covers on that one...otherwise Bosch Platinum plugs (the regular kind) are shorter than normal as well (its all I run)
WildRidez
Mar 27, 2015 08:22 AM
Jul 4, 2005 05:00 PM
Skull Leader
Aug 10, 2002 11:01 AM
