Pace Setter users, easy ?
Old Jan 14, 2006 | 01:01 PM
hulettsz28's Avatar
Do the pace setter LT headers and pace setter y pipe bolt directly together?
ALSO, what would be necessary to replace my cats with the y pipe and use the SLP LM exhaust, without cats. just the LTs, ORY, and slp loud LM exhaust? any fabrication or just bolt on?
Old Jan 14, 2006 | 02:01 PM
2000GTP's Avatar
Re: Pace Setter users, easy ?
The headers and y-pipe are actually a slip-fit style so there is no bolting done, just clamps. Slipping the y-pipe over the headers collectors can be a little tricky on the drivers side because of the floorboard.... I used a prybar and a shop rag, and gently pryed down on the header collector enough to slip the y-pipe over it. I'm not sure about your question regarding the cats. Are you asking if you can reuse your stock cats.? If so, they will fit into your ORY pipe.
Old Jan 14, 2006 | 04:01 PM
scottslt1z28's Avatar
when putting the y-pipe on i didnt bolt either side header in all the way so i could move them a little................made the job TONS easier
Old Jan 14, 2006 | 06:13 PM
hulettsz28's Avatar
no i am asking what i wuold have to do to not use cats. could i just use the pacesetter lts and the ory and the slp lm exhaust, without cats. like would the y pipe take the place of it? thanks
hulettsz28's Avatar
Old Jan 14, 2006 | 06:19 PM
2000GTP's Avatar
Yes, the Pacesetter ORY will not include catalytic converters. The headers will fit to the y-pipe fine, but you will have to either weld or clamp the catback to the end of your y-pipe.
Old Jan 14, 2006 | 10:36 PM
Z-RATED94's Avatar
You might want to purchase some better clamps then what come with the headers and y pipe.
Old Jan 15, 2006 | 01:00 AM
3gc's Avatar
3gc
There's really no fabrication to be done. The most that has to be done is cutting the intermediate pipe at the right spot and getting it expanded to slip over the y-pipe.
Victor Lamb
Aug 26, 2017 02:52 PM
Jlo
Jun 24, 2015 11:54 AM
maybe2fast
Apr 23, 2015 08:55 AM
cmsmith
Mar 14, 2015 03:48 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
