pac 1218's or patriot golds?
Old Feb 25, 2009 | 02:09 PM
sn8ke eatr's Avatar
i cant figure out which one to get. its for a 383 lt1 with a HR of approximately .600 lift. shouldn't see much past 6400 rpm because of the nitrous.
patriot kit:
https://www.patriot-performance.com/...&cat=52&page=2
pac springs + $150 for the rest of the hardware
https://securehost98.hrwebservices.n...&productId=183
i hear good things about pacaloy in general but the patriots are cheaper, and on paper look pretty much perfect for my application, and i haven't heard anything bad about em other then being made overseas.
so what do you guys think?? im on a budget but i don't wanna skimp on quality one bit.
suggestions?
-anthony
Old Feb 25, 2009 | 02:11 PM
87bandit's Avatar
I believe lloyd recommended me the partiots
Old Feb 25, 2009 | 02:17 PM
sn8ke eatr's Avatar
^ that helps a ton seeing as how im runnin le2's
thank ya bandit
Old Feb 25, 2009 | 03:19 PM
87bandit's Avatar
no prob
Old Feb 25, 2009 | 03:59 PM
wrd1972's Avatar
Patriots with the heavier 11/32 LT1 valves. My PACs caused me massive valve float and the motor petered out at 6K RPM.
Old Feb 25, 2009 | 04:12 PM
Bersaglieri's Avatar
I have never really liked beehives, so patriots get the nod from me.
-Dustin-
Old Feb 25, 2009 | 04:51 PM
krillformula's Avatar
I would go with patriots for that application.
Old Feb 25, 2009 | 09:31 PM
Z-RATED94's Avatar
Patriot Gold Extremes here, that just replaced some beehives, that replaced some 987s. This small Joe O. cam is an angry little bugger!
Old Feb 26, 2009 | 03:28 PM
greatskiiiier's Avatar
patriot > beehives, everybody knows that
Old Feb 26, 2009 | 09:05 PM
BLKOUTZ28's Avatar
Lloyd recommended and sold me these patriots https://www.patriot-performance.com/...2&bestseller=Y for my setup in my sig. Make sure you install them at 1.780 spring height (Recommended by Lloyd).
Old Feb 27, 2009 | 03:55 PM
sn8ke eatr's Avatar
thank you blkout ill probably get those
Bobczar
Oct 23, 2015 11:22 AM
Z Power
Sep 19, 2015 11:19 PM
RobFlag
Aug 29, 2015 11:40 PM
MadMav
Jun 15, 2015 09:51 PM
