P0507 Idle Control System RPM Higher Than Expected
Old Oct 16, 2006 | 11:57 AM
cleangene's Avatar
Ok, how do you fit this code, I have replaced the IAC valve with no help, idle is a little high and is not very steady, goes up and down, then steady again, seems to be better with A/C on. I thank maybe the TPS may be bad. No change when I replaced the IAC valve.
Old Apr 29, 2008 | 03:16 PM
DTI 00''s Avatar
check the throttle body that what i did
DirtyDaveW
Dec 1, 2016 05:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Fatdog2
Feb 13, 2015 08:19 PM
squarehead
Jan 15, 2015 07:02 PM
