P0507 Idle Control System RPM Higher Than Expected
Ok, how do you fit this code, I have replaced the IAC valve with no help, idle is a little high and is not very steady, goes up and down, then steady again, seems to be better with A/C on. I thank maybe the TPS may be bad. No change when I replaced the IAC valve.
squarehead
Jan 15, 2015 07:02 PM
