P0135 o2 Sensor code....
Old Jun 9, 2006 | 08:32 PM
Mike96z's Avatar
What does it mean? Codes on my PCM are:
P0101 Mass air flow sensor circuit, range or performance problem
P0135 Oxygen sensor heater circuit malfunction (pre-converter sensor, left bank) (drivers side)
Should I replace the o2? It's warranty BOSCH. Was all black when I took it out, only months old. Maybe the MAF made my car run lean/rich and took out the MAF? Thanks for the help.
Old Jun 9, 2006 | 10:53 PM
Re: P0135 o2 Sensor code....
The heater circuit of your O2 is not working. Either a wiring/connection issue or O2 problem. It would not "take out" the MAF. Many people find the Bosch O2s sensors problematic and will only use AC-Delco or Denso.
Your MAF code might be a fluke. I would clear codes and see if it returns.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
