P0134 code after header leak
Old Aug 2, 2014 | 08:51 PM
Greg88's Avatar
So my drivers side header bolt fell out causing my header gasket to fail now I have p0134 code (O2 sensor bank 1 sensor 1) no activity. Could this be from the header gasket failing? Now that sensor is cooked? How do I tell if it's the sensor Forsure and not the wiring etc?
Old Aug 2, 2014 | 10:17 PM
Kevin Blown 95 TA's Avatar
Re: P0134 code after header leak
I'd fix the leak first and see where that gets ya. I'm pretty sure an exhaust leak can cause that code.
Old Aug 3, 2014 | 05:10 AM
Greg88's Avatar
I did fix it already, sorry I didn't explain that. I erased the code twice and it keeps coming up. I'll drive it some more and see of it works it way out of the system.
Old Aug 3, 2014 | 09:24 AM
GaryDoug's Avatar
Prominent Member
I seem to remember Fred saying that certain adhesives/sealers can damage the O2 sensors. I don't remember the details however. Did you use any of those to fix the leak?
Old Aug 3, 2014 | 10:37 AM
P0134 indicates that the O2 sensor reading is static, in the range of 352-552 mV. That typically means there is an open circuit, and the PCM is "seeing" only it's own bias voltage (450 mV). Swap the left and right bank pre-cat sensors side-to-side. If the problem stays on Bank 1 (P0134), it's a wiring problem. If the problem follows the sensor to Bank 2 (P0154) it's a sensor problem.
Silicone ingredients in sealers like RTV can contaminate the sensors.
ChrisFrez
Feb 22, 2015 08:47 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
blac94Z
Nov 28, 2014 01:53 PM
Jul 4, 2005 05:00 PM
