P0133 & P0153
Old Sep 25, 2006 | 10:06 PM
antman's Avatar
P0133 & P0153
I recently received both a DTC P0133 and P0153. It seems suspicious that BOTH sensors would go bad at the same time. I monitored the sensors with a scanner while the engine was running and they both hit the 200mV - 400mV range even after clearing the codes. What could cause both of them to go off like that? Prior to the codes coming on, I had replaced the water pump and water pump seal. Could any of this work cause such codes?
Old Sep 26, 2006 | 09:05 AM
Re: P0133 & P0153
Sounds like they both got contaminated. Any chance you ran leaded fuel?
Huntr1117
Dec 8, 2012 09:07 AM
Need4Camaro
Dec 17, 2011 03:17 PM
RedRyder518
Aug 12, 2005 12:53 PM
