P0101 - MAF System Performance
Old Sep 18, 2004 | 07:21 AM
96ZRide's Avatar
Question P0101 - MAF System Performance
I have SES and pulled the P0101 code (only code set). The car still seems to run well.
I've searched and the only thing i found, that gives me something to go on, is to check the pink wire on the MAF (thanks INJUNEER).
I implemented the imfamous "EGR simulator" circuit several hundred miles ago to avoid the P0400 DTC because of low backpressure (Longtubes), which has worked...no P0400.
Does anyone know if it is likely/unlikey that this EGR simulator circuit solution could be causing the P0101?
I plan to check the pink wire and also log with Autotap sometime today. I just thought I'd post to see if anybody has some insight.
Old Sep 18, 2004 | 07:47 PM
Chrisbequick's Avatar
Re: P0101 - MAF System Performance
What's the EGR simulator circuit?
-Chris
Old Sep 19, 2004 | 08:12 AM
96ZRide's Avatar
-Chris
Someone on this board e-mailed me a schematic for it. I can look back and see / get the info, if you want.
Basically, attach a relay to the PCM's output to the EGR solenoid. The relay's output uses a 75 ohm ((2) 150 ohms, in parallel, in my case) resistor to put a small voltage drop on the MAP circuit.
Result: When the PCM commands the egr, MAP voltage drops a touch = PCM thinks EGR is working properly.
Its cool if you need to pass inspection via OBDII diagnosis.
I THINK that the system uses MAP to calculate MAF and compare it to measured MAF...if its not close, you get P0101...can anyone confirm that?
Old Sep 20, 2004 | 10:55 AM
Interesting info. You might try the tuning forum.
Good luck. Here's a free TTT!
-Chris
Old Nov 10, 2004 | 12:50 AM
superkia8's Avatar
Hey man, if someone has that schematic, could they email it to me?
superkia3@msn.com
Thanks,
Rich
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
