P versus H-series bearings
Old Mar 19, 2012 | 11:07 AM
Kurt Crosbie's Avatar
I am purchasing new bolts/bearings for my rebuild, and was dead set on using h-series bearings. I spoke with the guy that builds my racing engines, and he uses p-series bearings with a "coating" for the rod bearings. What do I really gain by using h-series if this is the case. This engine is using a stock crank and gm847 cam. It will see very limited track time (maybe twice for year).
Sent from my SCH-I800 using Tapatalk
Old Mar 19, 2012 | 04:06 PM
bowtiedad_z28's Avatar
Re: P versus H-series bearings
The P series will be fine for your build. If you where going with a aftermarket crank you would probably need H series since most aftermarket cranks have chamfered journals.
Old Mar 19, 2012 | 08:04 PM
Thanks. So are h-series bearings pointless for stock crank builds?
Old Mar 19, 2012 | 08:40 PM
No. I personally think they are a better bearing.
Old Mar 19, 2012 | 10:01 PM
Bersaglieri's Avatar
I'm doing a stock crank build right now, I haven't got to the bearings yet, but I'll let you know what we come up with and why.
Pretty sure we did H series in the 383 I built.
-Dustin-
Old Mar 20, 2012 | 06:19 AM
RamAir95TA's Avatar
P-series are overkill for what you're looking to do. While they won't HURT anything (only your wallet) they're usually reserved for the more hard-core racer with frequent teardowns.
Old Mar 20, 2012 | 06:54 AM
If P-series are overkill, then H-series must be superoverkill. Which bearings do I need?
I just want to be safe taking this to the road course at Carolina Motorsports Park and being able to really wind it out.
Old Mar 20, 2012 | 01:01 PM
Wouldn't it be equally as important to keep clearances right and keep oil clean regardless of bearing choice?
Old Mar 20, 2012 | 01:27 PM
raroz28's Avatar
I have run the p series in all my builds over the years and have never had a problem. My machinist didn't even recommend the nascar bearing, perhaps due to the fact that I am running a stock crank.
Old Mar 25, 2012 | 11:06 PM
Rob94hawk's Avatar
I have coated cam bearings. IMO I made the right choice.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
