P.O.S. CSI water pumped died...
*#@^$^$*%#*&^%*#@&%$...That's how I felt last night. It just died for no reason at all. It is less than a year old (about 7 months to be exact) and the motor in the pump just quit. WTF?
Mezierre here I come.
What problems have you guys had with your CSI pumps? Maybe I just had bad luck with mine.
I had a 15 amp fuse on it and it did not blow. There was not a short or anything that I can see. From what I can tell the motor in the pump just died. I took the pump and jumped it directly to the battery and it does nothing. DEAD
I drive the car all the time (it's my only car) and it has been good until last night. The motor in the pump just seems to have died for no reason.
Oh well... I am thinking about going with another stock pump. dunno yet though.
Originally posted by Mikael
CSI and Mezeire use the same motor.
Is it that they both use the same company to make the pump or is there more to it?
How do you wire the warning light?
I have a link to the schematics (sp?) page, but im no electrical engineer. Someone just tell me what goes where?
Jared
page is here http://www.akmcables.com/2ledmez.jpg
Jared
Originally posted by MrBigXL
just curious, did you have an indicator warning light? how did you realize it? was your temp going to the red?
Originally posted by atljar
OK looking at that a little more carefully, it seems that it will use the pump power wire as a ground if it shorts out? Correct?
But i still dont see how the bad ground light works?
Blood type Z28
Apr 8, 2015 11:34 PM
for a bit and see if anyone else had any bad luck with theres.
