P/N for pinion gear shaft (94 M6 3.42)?
Old Jun 29, 2003 | 05:39 PM
Polo-94Z28's Avatar
Cool P/N for pinion gear shaft (94 M6 3.42)?
Tried calling a local dealership... I honestly dont think the guy knew what I was talking about. But anyway, I am looking for the part number for the pinion gear shaft on a 1994 Z28 with M6 trans and 3.42 gears.
Thanks much
Old Jun 29, 2003 | 06:20 PM
97FormulaWS-6's Avatar
pinion gear shaft??? you mean the pinion gear? it's all one piece.... If you're thinking the "shaft" is bad... you need a new gearset.. it's part of the pinion gear.. or atleast that's what I think you're trying to say...
Old Jun 29, 2003 | 06:24 PM
anaik's Avatar
Doesn't the pinion gear shaft have the pinion gear attached to the end of it. You can't buy a pinion gear seperately. The ring and pinion come as a matched set. Just like bearings, they're matched to the race.
Old Jun 29, 2003 | 06:25 PM
If you mean this, it is GM PART # 26041321 .
Old Jun 29, 2003 | 07:56 PM
Polo-94Z28's Avatar
Thanks shoebox... was kinda waiting for your reply
Thanks all.
Old Jun 30, 2003 | 06:59 AM
hmm. learn something everyday... I thought that was the Differential C-clip retainer shaft...
Old Jun 30, 2003 | 07:33 AM
scoobysnax83's Avatar
Kinda sounds like you made that one up?!?
Old Jun 30, 2003 | 09:08 AM
That's kinda what I've always known it as... or as the axle retainer shaft, something along those lines...
I mean Pinion gear shaft? Where did that name come from, it has nothing to do with the pinion at all.. it holds the axles outward to retain the c-clips, and thus the axles...
Old Jun 30, 2003 | 09:10 AM
Without it how would you hold in the two other gears in the differential?
Now I don't know the names...
Old Jun 30, 2003 | 09:42 AM
the other 4 spyder gears are held in the diff with that Z shaped spring.. or the springs in the "posi" unit itself.
Old Jun 30, 2003 | 09:43 AM
It is because the gears that are in the differential are known as the differential pinion gears. Most people call them the spider gears or spider gears and side gears.
Airplanedoc
Parts Wanted
Apr 18, 2015 04:22 AM
blac94Z
Mar 6, 2015 07:55 AM
TitoPR221
Jan 29, 2015 08:00 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
