P/N PCV to Intake hose
Mine was pretty hard and I snapped it in half removing it from the intake. What's the p/n for this hose? Its on a 94, so its about a 4" U shaped hose. Unlike the 95+ where the PCV is connected to the front of the intake.
Re: P/N PCV to Intake hose
GM 10128361 -- About $11.50 shipped from GMPD.com. It'll be cheaper if you go elsewhere (eg, Jason Cromer: http://www.samtaylor.com/html/parts.html )
If you're needing it quicker, you might be able to find a hose at the local autoparts store that will work. Just bring in the pcv valve and see what fits. It should be 3/8" I believe...
Just go to the dealer. At most it will cost you $6. I just bought mine a few days ago (ripped it while taking out the intake) and it was $4. It has to be the prebent one due to a generic hose kinking at that angle.
Yeah thats what I was planning on doing. Thanks guys.
I should have clarified 'vacuum hose'. That stuff wont kink -- you'll actually be 'hard bent' on trying to get it to straighten out, in my experience (usually curved due to the way it is wound and packaged up).
Looks like autozone sells some vacuum hose going up to 10mm, which is just a tad over 3/8" -- perhaps it would work. Just a thought -- whatever's easiest...
[Edit] ~ And no, it doesn't make any sense to order a part like that. I don't know why I said that -- just out of repetition and tiredness I guess. Leave me alone.
