P.i.t.a!!!!!
Old Dec 9, 2003 | 03:26 PM
Heatmaker's Avatar
Advanced Member
Angry P.i.t.a!!!!!
Argghh! This was a pain in the *** getting the water pump off. The DAmn HAyens manual is horrible. I spent 15 minutes beating the hell out this thing trying to figure out why it wouldn't come loose. Only to find out it was a damn bolt! THe one behind the Bracket! The manual didn't even say anything about it!
My question is How do you remove the old water pump gaskets? Thier melted to the Block?
And while hte fans are out I want to upgrade them...what else is good?
Total PITA!
I think when I'm done I'll use the Haynes manual as an oil rag!
Old Dec 9, 2003 | 03:47 PM
2MCHPSI's Avatar
You can get those gaskets off by using a scraper or razor blade. It takes time and patience which it looks liek you have little from your post. LOL
Stock fans are more than fine. No need to upgrade the stock fans for any reason.
Old Dec 9, 2003 | 03:58 PM
Heatmaker's Avatar
Advanced Member
I forgot to say I have this dissorder that causes me to Hate all OEM products. Even if it's totally fine or not I have a need to Up grade it.
Old Dec 9, 2003 | 04:00 PM
Grease's Avatar
You can upgrade to Akimoto Type R carbon fibre cooling fans. They'll go good with the otherstuff in your sig
Old Dec 9, 2003 | 04:58 PM
97WS6SCharged's Avatar
May as well upgrade the radiator while your at it. Griffin and Becool make good ones and have high performance fan kits to match.
Old Dec 9, 2003 | 05:19 PM
eds96ragtop's Avatar
What is an electric turbo??? Is that like a fan on your intake??
Please forgive my ignorance.
And for god sake take the altezza's off your Camaro.
Old Dec 9, 2003 | 05:32 PM
madwolf's Avatar
This stuff should help with cleaning those gaskets.
Just kidding.
As an advice, when something doesn't come out easy, always look for what else may hold it in place instead of prying and possibly damage it.
Also, my manuals show all 6 waterpump bolts.
As for the gaskets, get some liquid gasket remover from a place like NAPA or Autozone. Spray and let it soak. Then get a blade scraper and scrape them. It will take a while and it's a very tedious job, but make sure you clean it well. I used a dremel on them before on my '95 Z, but on the '93, I had to use the procedure described above due to lack of electricity in my storage unit.
The key here is patience. Some of these things require a lot of it.
Good luck!
Old Dec 9, 2003 | 08:27 PM
S.J.S.'s Avatar
Yeah..just use a razor blade. After its all done I use thinner to get it all clean.
Just think my man. Next time you do it, it will be a piece of cake.
Oh yeah....go to the doctor and get some anti-aftermarket meds for your disorder.
Old Dec 9, 2003 | 08:37 PM
Heatmaker's Avatar
Advanced Member
Angry
F34K ME!!!!!!!
I get everything half done right in the middle of grinding and the damn dremmel dies out! WTF cheap POS!
Damnit! every time I try to do something something else f34ks up AARGG!!!
Old Dec 9, 2003 | 08:38 PM
madwolf's Avatar
Originally posted by Heatmaker
F34K ME!!!!!!!
Man, I'd recommend taking a brake before you work on it again. Also be careful with that dremel. It will shave the block too if you're not too careful.
Old Dec 9, 2003 | 09:27 PM
firehawk0152's Avatar
Remember to order 2 waterpump gaskets. You need 2 but they sell them individually.
Old Dec 9, 2003 | 09:31 PM
Heatmaker's Avatar
Advanced Member
Can I make my own gaskets? with that stuff they sell at Nappaheads?
Old Dec 9, 2003 | 09:32 PM
madwolf's Avatar
I don't see why you couldn't, but the cost of those two gaskets is under $1. Too much hassle doing it yourself considering the price.....
Old Dec 9, 2003 | 09:37 PM
longwaytofall's Avatar
i would personally just buy the right parts. before you coat the headers with the liquid gasket and blow smoke everywhere haha
Red95M6Z28
Wheels and Tires
Oct 21, 2008 04:58 PM
