Need some important info: Possible collapsed lifter
Old Dec 9, 2003 | 05:06 PM
Fastbird93's Avatar
After a thread coming to my attention on LS1.com and LS1Tech.com about the an individual having problems with a motor built by the same mechanic who did my h/c package, and realizing that I've been having continual troubles with my car since, I need to know a couple of things.
Can I tell if a lifter is collapsed by only removing the valve cover?? If not, what's the least intrusive manner I can check for a collapsed lifter???
I need to know this as my car is having the same symptoms as the other persons car.
Old Dec 9, 2003 | 05:14 PM
PoorMan's Avatar
I don't think a collapsed lifter is the installers fault. Is that what you are saying? I hear people say it "ticks" at different engine temps but that sort of vague.
Jeff D.
Old Dec 9, 2003 | 05:18 PM
Fastbird93's Avatar
Well, the car's never run right since I took it back. NEVER. I'm just trying to check my lifters, because this other individual had 5 collapsed lifters on his car, for no aparrent reason. I'm just covering my bases because I'm still having problems.
Old Dec 9, 2003 | 05:22 PM
PoorMan's Avatar
Sounds like the rocker arms are all too tight. This kills your performance too. Doing this CAN collapse the lifters if you go crazy tightening them down.
Jeff D.
Old Dec 9, 2003 | 05:27 PM
Fastbird93's Avatar
That's where it gets fuzzy. I've got one dyno sheet showing 375/363 on HP/TQ, and the mechanic said the car just ripped. Unfortunately, I wasn't there to see it first hand. I replace the tune with an updated one, and the problem arose. A/F was way rich, and a stumble/hesitation at fast throttle movement presented itself. Light throttle/slow throttle movement driving it's fine, but any relatively quick throttle movement and it hesitates and stumbles for a split second before picking right up.
Also, my oil has a gassy smell. I haven't drained it, but I took the driver side valve cover off and smelled it, so I pulled the dipstick and took a whif. Definitely a fuel smell.
I'm just trying to rule out the possibility of a collapsed lifter. There shouldn't be one, considering that the cam is only a 224/230 and I'm using Comp R lifters.
Old Dec 9, 2003 | 07:17 PM
PoorMan's Avatar
Sounds like the tune from this statement. Why did you replace it if the car "ripped" with the previous tune?
Jeff D.
Old Dec 9, 2003 | 07:32 PM
S.J.S.'s Avatar
Jeff D.
My first though......if not that then try and redoing the valve lash.
Old Dec 9, 2003 | 07:39 PM
flyinZ's Avatar
Sounds like, fuel has "slipped" past the rings, somehow...if you have a gassy smell in your oil...That could be caused from your tune, being too rich,etc...Try running the last "tune" that the car had..
Old Dec 9, 2003 | 09:42 PM
Fastbird93's Avatar
Well, I don't have that tune, and the reason it got replaced was because it was a bit lean up top. Working on it though. Just ordered a Pocket Programmer as I have the tune on my computer right now.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
