Oxygen Sensor Data
Old Aug 26, 2004 | 02:13 AM
disco192's Avatar
Oxygen Sensor Data
So my car is making a weird noise that sounds like some cylinders arent firing or something along those lines. I am also getting REALLY low voltage #'s at idle and part speed from my left o2 sensor. It reads about .08ish at idle while the other one is around .48-.52
Which is the left o2 sensor, drivers or pass side? Could fouled plugs cause this noise and o2 sensor readings?
Old Aug 26, 2004 | 10:57 AM
Re: Oxygen Sensor Data
At idle, and in part load cruise, your O2 sensor voltages should be fluctuating rapidly between 0xx-9xx mV. If one is stuck at 080mV, and the other around 450mV, you have a problem. Are they jumping around at idle or aren't they?
A 080mV reading would indicate a serious lean condition. A "stuck" 450mV reading would indicate an O2 sensor that isn't heating up.
Left = Bank 1 = drivers side = cyl's #1, 3, 5, 7
Right = Bank 2 = passenger side = cyl's 2, 4, 6, 8
Aug 24, 2015 06:41 AM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
BMX Dad
Aug 3, 2015 09:15 AM
BMX Dad
Jul 27, 2015 02:39 PM
