Is this an overtightend valve???
Old Aug 22, 2004 | 08:43 PM
ChevyTuffD.A.'s Avatar
I just changed the fuel pump and now i have good fuel pressure. At the same time i had a rocker arm ticking under the hood so we pulled the valve cover and we found a rocker that was alot looser then any of the others so we tightend it, im thinking we prolly tightend it about 2 full turns until it wouldnt wiggle so much, well we started up the engine and the ticking went away but after about a minute of the car being started i have this sound coming from the exhuast and it kinda makes this tu....tu......tu.tu sound kinda speradically i am pretty sure sitting here that it was the #5 intake valve, we took the valve cover back off and backed it off about half a turn and then we started it back up and then it still did it after about a minute of the car being running, I never had this problem before i touched the rocker arm or replaced the fuel pump bc we did both at the same time. I would think that the valve is still too tight and needs to be backed off some more but i wanted a second opinion. The rpm's stay pretty steady but i just have the sound coming from the exhaust. Would an overtightend valve cause this problem???
Old Aug 22, 2004 | 09:00 PM
Built on Sin's Avatar
Re: Is this an overtightend valve???
I would remove rocker and readust it.
If it was loose and you just crank it down, you have know idea where you are at.
Old Aug 22, 2004 | 09:04 PM
12SCNDZ's Avatar
Instead of guessing, why not start the car up with the cover off and adjust the suspect valve correctly? Loosen until tap occurs and then tighten until tap goes away, and then set preload. Since I'm not sure what your others are set at, I can't say how much preload you'll want. I only went 1/8 turn past zero lash (when tapping first stops).
Frank
Old Aug 22, 2004 | 09:06 PM
Well i am almost positive that we tightend it too much, so i think we are just going to back it off a little at a time prolly like a quarter of a turn and then see if it eventually goes away. Would this overtightend valve cause the problem that i mentioned??
Old Aug 22, 2004 | 09:23 PM
sent you a pm
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
