oversized valves in stock heads
The 2.00 and 1.56/1.57 's will fit with stock seats BUT the seats will need to be machined for the to work. You do not have to REPLACE the seats like you would if you go with 2.02/2.05' and 1.60's to get them to seal correctly.
Just making sure that you are not just "installing" the valves with NO machine work. As long as there is a valve job done for the larger valves than they will work fine. If you just put them in the heads with NO machining, they will NOT work. Just take the valves to the machine shop with the heads and tell them to "make these valves work with these heads".
NightTrain66
NightTrain66
WOW thats close... you have a phone number I can hold onto till im ready for the headwork, I would send them off but ive heard great things about your work and NO SHIPPING CHARGE!!!!
