overheating...please help
Old Jul 31, 2006 | 10:24 PM
frankthetank078's Avatar
i had my thermostat and my fans redone about a month ago, but today when i drove my car about 6 miles away when i parked i noticed my temp at 220 and slowly rising. I came out about 30 min later, the guage read 160 (which i thought was wierd seeing how it dropped so rapidly) and i noticed the low water sign was on. So i added a little over 2 quarts into the radiator and it took all of it...who knows how much more i could have added but what does this problem sound like? thanks
Old Jul 31, 2006 | 10:56 PM
lt11997's Avatar
Re: overheating...please help
You more than likely have an air pocket in you cooling system.
Old Jul 31, 2006 | 11:00 PM
mthegodfather's Avatar
You should bleed the system and refill it and see if that doesn't solve your problem.
Old Jul 31, 2006 | 11:05 PM
good ideas...how would i no if its the electric water pump?
Old Jul 31, 2006 | 11:19 PM
lt11997's Avatar
It would be leaking out of the weep hole on the bottom of the water pump.
Old Jul 31, 2006 | 11:37 PM
6SpdLT1Z's Avatar
Low fan comes on at 226, high at 235.. Once your at 235 if it keeps going up THEN you have a problem.
http://shbox.com/1/4th_gen_tech2.html#cooling
Old Aug 1, 2006 | 12:07 AM
my fans are on constantly tho..even when i just put my battery on like to listen to the radio or put the windows up they come on..
