!! overheating !!
Old Jul 29, 2003 | 01:48 AM
firstgener's Avatar
Angry !! overheating !!
MY 95 z seems to always over heat. I have changed the relays for the fans and also the temperature sensor. My fans dont seem to kick on and it happens just like that. I will drive five miles to work and get there and the over flow will be spraying every where. Please help i have to drive out of town tomorow and need your advice.
Thanx
Austin
Old Jul 29, 2003 | 08:37 AM
Just as a quick response, have you replaced the radiator cap?
Old Jul 29, 2003 | 09:18 AM
RENE95Z's Avatar
Have you bled the air out of the system?
Old Jul 29, 2003 | 09:23 AM
jasons93z's Avatar
put in a manual fan switch
Old Jul 29, 2003 | 09:52 AM
raceryan's Avatar
The answer could be as easy as the thermostat not opening when it should. You can test it by pulling the stat out, and put it in boiling water a little above the stamped temp rating (20* or so should sufice) on the stat. It should fully open within a minute. then add colder water to the stat and see if it closes properly. Careful, its hot.
Old Jul 30, 2003 | 01:14 AM
96LT14u2Nv's Avatar
yeah, start with the small stuff first(ie. radiator cap,put in lower temp thermo,manual fan switch) and see how it goes. if none of that, look into a H20 pump or radiator
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
