Overflow grommet
Old Apr 30, 2015 | 05:20 PM
blac94Z's Avatar
Overflow grommet
Coolant is slowly leaking out do they sell these ?
Old Apr 30, 2015 | 05:40 PM
Re: Overflow grommet
If you are talking about the overflow pipe and grommet that goes into the top of the battery tray/reservoir, they are both discontinued from GM.
Old Apr 30, 2015 | 06:25 PM
blac94Z's Avatar
Oh my . So what would be my choices for changing this grommet that goes on the overflow
Old Apr 30, 2015 | 06:42 PM
Bone yard.
Old Apr 30, 2015 | 08:56 PM
blac94Z's Avatar
Thought so thank a lot bro
Old May 5, 2015 | 12:38 PM
94Z28LS1toLT1's Avatar
Hey bro did u find one at wreck yard
Old May 6, 2015 | 01:22 PM
blac94Z's Avatar
havnt had a chance to run to the pic a part just yet have you been back to the one on lamb ?
Old May 6, 2015 | 06:35 PM
Yea the one on lamb had sum v8s there I was just there Tuesday
Old May 6, 2015 | 10:40 PM
GaryDoug's Avatar
Prominent Member
This one might have what you need: http://www.ebay.com/itm/93-02-Camaro-Z28-Firebird-Trans-Am-WS6-Coolant-Recovery-Tank-Reservoir-/371301843929?hash=item56735083d9&vxp=mtr
Old May 6, 2015 | 11:24 PM
Fatdog2's Avatar
Originally Posted by GaryDoug
Parts train has one for a 93 for $24.00.my02.
Old May 7, 2015 | 10:10 AM
Maybe seal the grommet by applying RTV to both edges.
Just a thought - why would coolant be leaking at the top of the container? Overfilled? Shouldn't be possible.
V8 and V6 overflow/battery trays are identical... no need to limit your search to V8's.
Old May 7, 2015 | 01:10 PM
blac94Z's Avatar
thanks you guys for your help
I may try the RTV bc its not leaking more like a small pool of ANTIFREEZE sitting in the hole on top of grommet where the tube inserts if you get what im saying ?
Old May 7, 2015 | 02:57 PM
I wonder if the rubber hose or the metal tube is cracked, coolant running down and pooling on the top of the reservoir?
Old May 7, 2015 | 04:17 PM
blac94Z's Avatar
no its the grommet I changed the hose and rubbed a little lucus trans slip on it and it has worked to the point there no air in my system any longer but it just has a little
water on top
Old May 7, 2015 | 04:18 PM
blac94Z's Avatar
only on top of grommet not reservoir
