Overdrive not working?
Old Mar 10, 2003 | 12:37 AM
Jason Novak's Avatar
I have a friend with a 95 camaro that's been in storage for a while, and now overdrive doesn't seem to work. It's always turning 3000 RPM at 60 MPH whether in D or OD, I know my car is just under 2000 RPM in OD. Shifting between the two gears does nothing, RPMs stay the same, there's no "jerk" as it shifts, and no clank or gear grinding that might indicate a problem. There are no warning lights on. Anyone have any thoughts?
Old Mar 10, 2003 | 12:42 AM
thebrainhart's Avatar
Does his first gear work?
When my 2-3 shift selenoid went out, it caused a loss of 1st and 4th (OD) gears.
Old Mar 10, 2003 | 12:38 PM
I don't think that was the problem but it did fix it He tried shifting into 1st and 2nd and it did appear to be engaged different gears correctly, but ever since then OD has started work, maybe something was stuck after sitting for a couple monthes?
Old Mar 10, 2003 | 12:46 PM
1fast95Z's Avatar
Sludge and other particles in the valve body might do it. You might consider flushing and changing your transmission fluid and filter.
jb4xx
Feb 2, 2015 10:00 PM
Snoman73
Nov 17, 2014 07:22 PM
Caps94ZODG
Sep 7, 2002 10:09 PM
Caps94ZODG
Jul 1, 2002 10:20 PM
Caps94ZODG
Jun 23, 2002 02:19 PM
