Over heating after brand new rebuild.HELLLLP!!
Old Mar 12, 2016 | 09:29 PM
  #16
95maroboi's Avatar
Re: Over heating after brand new rebuild.HELLLLP!!
Originally Posted by TGGodfrey
What your going to need to do at this point is to get a temp reading on the coolant as it enters the radiator and as it exits to see if your radiator is reducing the coolant temp.
do you have a fluke or another type of meter that has an electronic thermocouple?
Something like this would work, you need to be able to get a reading of both inlet and outlet at the same time.
H-B Instrument Durac Electronic Thermometer, with Alarm and Timer, with 152mm Probe and 1.5m Stainless Steel Cable, -50 to 300 degree C: Amazon.com: Office Products
Take your hose off and clamp the thermocouple into the hose. This will leak a little during testing but your not too concerned about that as long as the hose clamps are tight and hoses are not blowing off.
Compare your incoming temp on the radiator to your outgoing temps..... Obviously if the coolant entering the motor is not cool, then the radiator and/or fans are not able to keep up. There is also the possability that the water pump is pushing coolant through the radiator too fast and not allowing the radiator a chance to dissipate heat. An Aluminum radiator might be required. This test will at least put you on the right track as far as what is causing the temps to keep increasing.
Like mentioned before, verify the pump is still running when your fans kick on from low to hi. You can do this without running the car, just jumper the relays on low, verify water pump is getting power, jumper the fans to hi and recheck the pump feed.
Here is a shot in the dark.....I didnt see where you mentioned any type of ECU tuning. Did anyone retune the timing maps in your ECU and perhaps maybe they advanced them too far causing this? Pull your plugs and read them for timing.
It's not the radiator.i had a Griffen radiator on it and it was still over heating so I went back to stock to see if that would help any witch it didn't . I use a laser temp gun on top hoses and the tempatures were around 200-205. The car hasn't been tuned for this set up yet cuz the over heating issue .the car is running a little rich so I know it's leaning out. I'm pretty sure it's got to be the fans I'm using. The fans are only 850 cfms each and when I called spal for some new fans they recommended fans that do 1600 cfms each.
Old Mar 12, 2016 | 10:20 PM
  #17
Thirim's Avatar
no idea on the stock fans' cfm rating but they both only come on with the AC or above a certain temp... like 220/230 or something... Granted you don't have a stock motor either..
Idling ok? No vacuum leaks? I know leaving the brake booster off the intake makes red headers quicker than you can find the problem lol.... whoops!
Old Mar 13, 2016 | 10:00 AM
  #18
Late 94 on up both fans come on, low speed at 226-degF, or with AC; both switch to high speed at 235-degF. My stock fans/Griffin radiator setup has no problem handling the engine with the 300-shot of nitrous.
The fact that the problem lessens at idle when he turns the fans off seems to point to the fans. The other possibility is that somehow the power source for the electric water pump is interupted when the fans turn on.
Old Mar 13, 2016 | 07:27 PM
  #19
95maroboi's Avatar
The car is programmed to turn the fans on at 180 degrees when the thermostat opens .no vacuum leaks.the idling is fine.loads up a bit when you first start it but when you rev it a little bit it cleans itself up
Old Mar 13, 2016 | 07:31 PM
  #20
95maroboi's Avatar
It's when I have the engine off but the key in the on position it's cools off with the fans off and just the pump running. It's been raining the past week here in California so I haven't had the chance to try to fit the stock fans back in. It's gonna be a challenge sense my current fans are 2.75 inches thick and only a inch away from touching the super charger pulley
Old Mar 13, 2016 | 09:52 PM
  #21
gaedbo's Avatar
As an observer reading the threads, it sounds like the fans are blowing the air into the radiator, instead of pulling the air through the radiator towards the engine.
Old Mar 13, 2016 | 11:33 PM
  #22
95maroboi's Avatar
The fans are pulling air from the radiator into the engine. We verified that with our hand and a piece of paper
Old Mar 14, 2016 | 04:53 AM
  #23
timnfxr's Avatar
Is it possible to mount the fans in front of the radiator in a push direction?
Old Mar 14, 2016 | 09:10 AM
  #24
I think some forced induction guys stand the radiator upright for more room for fans.
Use a clamp on ammeter to verify the water pump does not shut off when the fan relays kick in.
Old Mar 18, 2016 | 07:00 PM
  #25
95maroboi's Avatar
The water pump is pulling 7 amps with the fans on .
Old Mar 28, 2016 | 12:39 PM
  #26
TGGodfrey's Avatar
Looking back through some of the posts to determine what you have changed with the motor/SC setup.......... You added a few cubes and upgraded you SC trim.
You have checked flow direction, Alum or factory radiator still does it, Pump is operating with fans on, twin 850 CFM fans (should be enough at idle).
Have you checked what your timing is doing at idle when your dealing with this? If you timing is advanced more than normal, thats going to contribute to overheating as well.
Another thing that sticks out like Fred mentioned is with the fans off the issue seems to lessen. Do this for a simple test. Run the pump direct to the battery and see if it still does it. Depending on where your power is coming from on the pump you could be starving the pump for voltage (not amp) when the fans kick on. At that point it appears the pump is drawing enough amps but its not getting enough voltage to operate at the correct speed.
You didnt mention where the pump is getting its power and I wonder if the shop tapped into the main feed for the fans. This could lead to a line loss issue on the wire due to the current draw on undersized wiring. Aftermarket higher CFM fans are only going to make that worse.
edit: Remember Amperage and Voltage are inversely related. Meaning if your voltage sags, the amperage draw will increase. Motor will still spin slower.
Terry
Old Mar 28, 2016 | 08:05 PM
  #27
bw_hunter's Avatar
I just went out and checked mine. The pump draws 6.5 amps and 8 seems a little high. Mine is the wp118hd
I have mine wired with a relay directly to the battery (circuit breaker in line, of course, with a trigger coming off the a hot wire on key on or acc. I had 14.2 volts at the pump pigtail and the engine running...essentially alternator output.
I hope this helps...
Old Mar 30, 2016 | 08:15 PM
  #28
95maroboi's Avatar
Terry
I haven't checked the timing yet . Now that you mention somthing about the volts I forgot to add I'm only getting 12.5 volts at idle. The battery is rear mounted now. We have a cable going from the negative battery terminal to the body of the car and the positive terminal directly to the stater .
Old Mar 30, 2016 | 08:20 PM
  #29
95maroboi's Avatar
I also have the same one you do. Mine is pulling 7 amps. According to summit it should be pulling 8 amps http://m.summitracing.com/parts/mez-wp118hd
Old Mar 30, 2016 | 09:58 PM
  #30
Thirim's Avatar
as you bring the RPM up, how does the voltage change on the battery? I'd still look at the timing though. at idle with fans and pump on it's still 12.5 or does it drop more? .. Fan rpm will drop as the voltage does. Is it a custom tune? .. do you have the spark advance table if so? .. Have a wideband O2 sensor? .. Curious how lean it is at idle.
