Over Heating After 180 Thermo Install
Old Mar 24, 2008 | 10:58 AM
texas94z's Avatar
I did a 180 thermo install and my green car is over heating very quickly. I thought there was air in the lines so i bled it many times. I topped it off with 50/50 and still i am over heating. It was running perfectly untill i did the install. Also, i just installed a tranny cooler in place of the a/c condenser. Do you think the heat from the tranny cooler is causing the radiator to get hot? I think i am going to bypass the heater core next cuz maybe its clogged. Any suggestions?
Old Mar 24, 2008 | 11:05 AM
Pontiac_97's Avatar
there is no way the tranny cooler is getting that hot to overheat the radiator. you sure you seated the thermo stat correctly? how hot does it get?
Old Mar 24, 2008 | 11:33 AM
texas94z's Avatar
ill check if its seated correctly. the water temp gets to 240-250ish. i killed the car before the temp gets higher.
Old Mar 24, 2008 | 11:37 AM
moparman's Avatar
Did you get the correct LT1 thermostat? The standard small block Chevy one might not work properly.
Old Mar 24, 2008 | 11:39 AM
Is it an "LT1" thermostat?
Old Mar 24, 2008 | 11:40 AM
guest74777's Avatar
Guest
the sbc one will not fit correctly if thats what he used you need a LT1 specific stat
Old Mar 24, 2008 | 11:42 AM
texas94z's Avatar
yes it is a lt1 thermo.
Old Mar 24, 2008 | 02:22 PM
moparman's Avatar
Take the new stat and put it in a pot of boiling water and see if it opens.
Old Mar 24, 2008 | 02:36 PM
bombebomb's Avatar
+1 if its boiling hard and dont open, you have bought a brand new paper weight. You can use a thamometor also (wow my spelling rocks).
Old Mar 24, 2008 | 06:14 PM
96 Z 28's Avatar
I would try bleeding the air out again. and again. and again.
When I put in my 160 Deg Thermostat, I had the same problem. My buddy stopped by and pointed out that the hoses were soft and cold.... then suggested we bleed the air out
So well we bleed the air out agaain and voila Problem solved
So i'mma gonna be that guy and say 'Bleed the Air Out'
Or as suggested you may have a bad Thermostat
Old Mar 24, 2008 | 08:32 PM
Air in the system is a lot more common than a bad thermostat.
Nov 18, 2023 07:21 PM
Jan 23, 2015 01:13 PM
ro2207
Dec 4, 2014 06:18 PM
thenewkid
Nov 27, 2014 09:41 AM
smackkk
Jul 22, 2002 05:17 PM
