Over Heat
Old Jul 9, 2003 | 03:46 PM
OffspringZ28's Avatar
Over Heat
A while back when my water pump died all my coolant leaked out while i was far from home and had to drive home with the gauge at red. Yes i did pull over and let it cool a couple of times. Whats the worst that could happen? Blown head gasket? Could a blown head gasket cause that "low rpm stumble"? There is a little whitish/clear smoke at start up when i get on it but it seems to just be condensation. The car also does not overheat.
Old Jul 9, 2003 | 03:51 PM
ZDriver96's Avatar
worst that could happen,
crack your block, crack your heads.
stumbles are usually caused by fuel problems, or ignition problems
Old Jul 9, 2003 | 03:52 PM
mirroredfire2's Avatar
I did that once in a honda and it warped the gasket =O personally id walk all the way home before id drive my camaro when the water gauge was in the red .. alls i can say is good luck
Old Jul 9, 2003 | 11:55 PM
car seems fine.....oil checked out fine as well as the coolant....whew.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
