OVC wires- How does the passenger side route? Behind the pulleys still???
Old Aug 7, 2005 | 02:04 AM
Black1995Z's Avatar
Arrow OVC wires- How does the passenger side route? Behind the pulleys still???
I'm having trouble with my wires being sliced by the pullies on the passenger side... will an OVC kit take care of that? Anyone have pics or a diagram of how the wires are ran/routed?
Also, which are the easiest to install... I know the "do it yourself" kits are a pita.
Old Aug 7, 2005 | 02:06 AM
Birdman7389's Avatar
Re: OVC wires- How does the passenger side route? Behind the pulleys still???
The do it yourself is not bad, just get a tube of silicone lube and its fine. I got mine from thunder. Mine are routed behind the PS pump, and under the alternator on the passenger side. No problems in 10K miles on one car, and 10K miles on another.
Old Aug 7, 2005 | 02:08 AM
Black1995Z's Avatar
Well, my accessory bracket is missing the clips for the wires.. thats whats causing my problem. I was hoping it would get around the ps pump somehow.
Do you use the clip for the wires?
Old Aug 7, 2005 | 02:18 AM
LS1_03's Avatar
Had no idea the power steering pump was on the passenger side.
luckyou03's Avatar
http://www.adamshipley.com/camaroz28...res/driver.jpg
http://www.adamshipley.com/camaroz28...wires/pass.jpg
http://www.adamshipley.com/camaroz28...ires/pass2.jpg
Old Aug 7, 2005 | 02:22 AM
Black1995Z's Avatar
Great routing! What kit is that?
And where from!?
Great motor, I love the colors.
Old Aug 7, 2005 | 02:26 AM
luckyou03's Avatar
Thank you! Those are from thunder racing and well worth it. I went through 3 sets of autozone and MSD wires before I switched to those. Haven't burnt a single wire yet.
The install was a pita, the boots are the hardest part but do-able. Make sure to run the wires and cut them to size before you install the boots. I thought they were precut to length, but they are NOT!
Old Aug 7, 2005 | 02:28 AM
Black1995Z's Avatar
What makes the boots so hard to assemble?
If I bought a precut wire would it be too long/short to route it the way you have yours?
Your routing looks fail-safe
Old Aug 7, 2005 | 02:33 AM
luckyou03's Avatar
Well it's rubber to rubber contact. When you try to shove a rubber boot on a rubber wire coating they like to grip each other. The silicone lube does help, but my best method was to insert needle nose pliers into the rubber boots and stretch them out a little first.
I'm not really sure about the fitment of the other
precut" wires. I think the thunder racing set is best because it comes with a lot of extra wire, I have enough extra to replace one wire incase one burns.
Old Aug 7, 2005 | 02:48 AM
http://ken.lowrance.com/Projects/Hea...odyGoingUp.jpg
http://www.michiganspeed.com/enginepull/stands.JPG
Right under the alt?
Old Aug 7, 2005 | 08:58 AM
ABA383's Avatar
The way Luckyou routed them is the way i did it, too, and so far, after over a year, they are still fine. The only other thing I did was to zip tie the wires together after they drop down from the alternator just to keep them from getting caught up in the pulleys. Putting on the boots can be a pain, but just get some silicone spray and use a lot. You'll then need to use rags in your hands to get some grip and then push the boots on...
--Alan
Old Aug 7, 2005 | 09:34 AM
FastZinTennessee's Avatar
This would be the way to do it. It's how I did mine because it's such a pain in the *** to route behind the PS pump. Plus, with the larger wires I'm not really sure they'd fit in the factory routing thing and stay in place.
Old Aug 30, 2005 | 03:45 PM
Black1995Z's Avatar
Does anyone know if these will route the same way?
http://www.elitesparkplugs.com/LT1sparkplugwires.html
The 8mm PRE-cute OVC wireset
Old Aug 30, 2005 | 05:28 PM
2000GTP's Avatar
Yes, I just installed the Elitesparkplugs.com OTVC wires and the centerbolt wireloom kit from Thunderracing.com Anyways, the routing of my wires turned out identical to luckyou03, but I'm sorry I dont have pictures of it yet. Just make sure you zip tie the wires around the power steering pump pulley area and tuck everything up real nice and you shouldn't have any problems.
Old Aug 30, 2005 | 05:32 PM
AXEMAN's Avatar
luckyyou03, when I get my headers installed I will be looking you up to get a better idea on how to route my wires. That motor is looking great.You should post pics on the local club site.
camaro98_speed
Apr 22, 2015 11:26 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 10:43 PM
