Out with the LT1 in with the Gen I... Estimates?
Old Oct 30, 2006 | 05:59 PM
1BadZ95's Avatar
Out with the LT1 in with the Gen I... *PICS*
Hello all, well we've had nothin but problems with the LT1 in my 95 Z28 it seems so we've decided to go with a good ole Chevy Small Block. The motor is a balanced and blue printed 4-bolt main, 355ci sbc, steel crank, Weisco Forged Flattop pistons, all forged bottom end, Comp Cam Hyd roller 230/236 561/573lift, 1.65rr's, Super Pro Series Patriot Aluminum Heads - C&C Bowl blended, flow = in.600L/263, ex.600L/184, in. 2.02 ex. 1.60. Intake Im not sure of, what do ya'll recommend? I'm thinking about going with the Edelbrock Victor E EFI intake, but its up there in price. This will go in my 95 M6 Z28. What kinda numbers do you guys think it should put down?
Old Oct 30, 2006 | 08:11 PM
Dennis93TA's Avatar
Ohh man your pulling out the LT1???? Come on, don't quite on us. That's the purpose of the lt1 IMO. Not just anyone can build one, and you did!
If your gonna do that though, i would choose a bigger cam for it. Are you going carb or no? If so I recomend the Victor Jr. intake. With that combo i would say about 450fwhp. Thats about the same setup in my '67.
If your really getting rid of the lt1 let me know, i'll buy some parts from you.
Old Oct 30, 2006 | 08:16 PM
1BadZ95's Avatar
Yup its already out lol. I'm stayin Fuel injected and will still use the opti (custom setup). I'm thinkin about goin bigger cam but I already have spent a bunch of money and this is my daily driver...
Old Oct 30, 2006 | 08:17 PM
Jerm93z28's Avatar
ill say you might pick up 20-30rwhp if the compression remains the same as the LT1.
kline454's Avatar
yeah why pull the lt1? you can do anything you want on a lt1, seems like you should put down good numbers but, i would do it with an lt1!
Old Oct 30, 2006 | 08:21 PM
1BadZ95's Avatar
No, compression will drop prob around 9.5:1. Thats part of the reason, although I could just buy new heads for the LT1 We already had this one at the shop. I can't keep the LT1 from pinging on pump gas. And it also has blown a few head gaskets. Who ever had the car before me milled the heads way to far.
Old Oct 30, 2006 | 08:31 PM
Dennis93TA's Avatar
If that's the only thing holding you back i have a set of stock heads i just took off to make room for the gtp's and i'd work a deal with my fellow CCFB guy if he wants them!!
Old Oct 30, 2006 | 08:46 PM
1BadZ95's Avatar
Nah, thats not whats holding me back. This will just be a better all around motor.
Old Oct 30, 2006 | 08:53 PM
bombebomb's Avatar
Another bad thing on taking it out is this.
What motor does that got in it?
a 355
instead of
it gots an LT1 in it, corvette motor.
Old Oct 30, 2006 | 08:56 PM
1BadZ95's Avatar
Nah, thats alright. I never told anyone its the corvette motor anyways. Actually what I said when that question was asked was... Just a stock 350 with a mild cam.
Old Oct 30, 2006 | 08:59 PM
Sparkz28ss's Avatar
why get rid of the LT1....and keep the opti?
Old Oct 30, 2006 | 09:20 PM
Jerm93z28's Avatar
what were you planning to do for the opti signal? i know you said you had plans.... im just curius
Old Oct 30, 2006 | 10:01 PM
1BadZ95's Avatar
So we can use the same computer...
Moved the sensor into a custom distributer. Just for the sensor. Will use LTCC still. I'll try to get pics later.
Old Oct 31, 2006 | 11:12 PM
1BadZ95's Avatar
Think it will hit 400rwhp?
Old Nov 1, 2006 | 10:56 PM
JimboManJones's Avatar
It seems like you are just trying to reinvent the wheel here, whats wrong with an lt1, in simplest terms its a reverse flow cooling, fuel injected gen 1 with a funky distributor, your keeping the funky distributor, and the fuel injection, so why don't you want the lt1?
