OTVC wire routing (Pass. Side)?
Old Jan 5, 2006 | 10:13 AM
gamecockfan04's Avatar
Whats the easiest way to route the OTVC wires on the passenger side? I bought the precut Elite OTVC wires and did the drivers side in no time, but I know how much of a pain the regular wires were to route on the pass. side and am simply looking for he easiest way to go.
Old Jan 5, 2006 | 10:20 AM
wrd1972's Avatar
Re: OTVC wire routing (Pass. Side)?
Remove the plastic wire guide loom that was used for the stock wires from behind the power steering pump, chances are it wont fit your elite wires.
Loosen the two bolts to slide the PS pump forward for more room to work and start the routing, dont remove it.
Starting at the opti and neatly route them behind the PS pump and tube and slightly under and around where the altonator goes and then to the looms on the head or valve cover.
Do this with the altonator removed and it will become clear.
Old Jan 5, 2006 | 10:45 AM
Hawk's Avatar
i have elite wires and OVTC setup. Driver side was easy. Pasaanger side was harder, I routed it like mentioned above. However, I found the wires to be a little on the short side and they didn't work out "perfectly" but they got the job done. Next time i have to do this, I will think about not going behind the power steering pump and actually going up the other side of the alternator, should get some more slack that way..........
Old Jan 31, 2006 | 12:12 PM
Coop1's Avatar
Anybody have pics of how these things are supposed to be routed. A little confused on how they are supposed to route on pass side.
Coop1's Avatar
Anybody have pics of how these things are supposed to be routed. A little confused on how they are supposed to routed on pass side.
Old Jan 31, 2006 | 06:40 PM
CamaroSS30thAnn's Avatar
http://ken.lowrance.com/Projects/OVC...OVCInstall.htm
mattstrike
Mar 11, 2015 07:33 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
pimpss96
Feb 12, 2015 01:28 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
