OTV Spark Plug Wire Recommendations
Old Sep 21, 2012 | 09:57 PM
gelbza's Avatar
I've been searching for about 2 weeks now for OTV wires for my LT1. So far every set I've bought I've had to return for various reasons, like being too short, wrong plug ends, etc. Can anybody recommend some that are good quality and will fit properly? My max range is about $80-90.
Old Sep 21, 2012 | 10:32 PM
97z28k&N's Avatar
look on ebay for a gently used set. I got MSD wires that were nearly unused for about $20.
Posted from Camaroz28.com App for Android
Old Sep 21, 2012 | 11:44 PM
gelbza's Avatar
Do you know the part # for the MSD's?
Old Sep 22, 2012 | 10:54 AM
RamAir95TA's Avatar
Re: OTV Spark Plug Wire Recommendations
If that's your price range you won't be getting new OTVC wires.
Personally though OTVC wires are more of a pain in the *** than anything else. They make cleaning the valve covers impossible, can actually burn WORSE than OEM routing, and generally look tacky and make the engine bay look too busy.
After a year of having them you'll see what I mean.
Conventionally routed stock wiring is the best to prevent burning.
Old Sep 22, 2012 | 11:32 AM
gelbza's Avatar
How do they result in more frequent burning? It would seem that stock routed wires can bounce around more and land on the headers, whereas these will be secured to the valve covers and unable to move.
As for cleaning, I have the MadeForYou clamps, so it just a matter of a hex bolt each to move them out if the way.
I went ahead and ordered the $135 MSD kit, so yeah I jumped my price a bit.
Old Sep 22, 2012 | 11:50 AM
RamAir95TA's Avatar
Stock routed wires have looms and brackets to physically keep them away from the hot manifolds. They hug the block and keep the wires further away from the headers than OTVC wires. Eventually zip ties will heat up, cool, heat up, cool, and eventually fall off. Not to mention to keep the wire signal clean wires should not touch eachother. I understand in a perfect world this may not be possible but OTVC wires make this much more difficult.
A "matter of removing a hex bolt" might seem easy to you but that's eight bolts you have to remove just to wipe down the valve cover. And because you have to remove those bolts every time you'll be less likely to keep it clean more regularly so in turn it will begin to look worse. Just saying.
I went through two sets in 3 years and said screw it. There's a reason stock cars don't burn wires even after 19 years because the factory routed them properly.
But hey, it's your car. I'm just offering up my experiences, and my experience says OTVC sucks.
Old Sep 22, 2012 | 12:29 PM
gelbza's Avatar
That's cool, no problems. I do appreciate the insight.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
