orings on the opticoil shaft?
Old Apr 13, 2007 | 11:40 PM
ben50520012000's Avatar
im in the middel of putting on good used opti on my 1994 lt1 and read that the opticoil shaft has 2 orings.. is this true? what are they needed for? does any one know the part number? kinda odd the dont come in the timing cover gasket set!
thanks
Old Apr 13, 2007 | 11:58 PM
henryz28's Avatar
I just did a cam swap and the little rubber o rings came with my timing cover gasket set.
Old Apr 14, 2007 | 12:16 AM
really? cus i think 1 is for the water pump timing cover shaft. and the other oring is for the water pump shaft
CUS FELPRO ONLY GAVE ME 2 BLACK ORINGS
Old Apr 14, 2007 | 12:38 AM
henryz28's Avatar
Ya I got 4 but I just reused the old ones.seems to be fine;but If you want new ones you could just take them off the shaft and take them to Auto zone and they should have some to match them.Their only like 25 cents.
Old Apr 14, 2007 | 01:25 AM
just looked on both opti coil shafts and there are no o-rings..so im probley gonna go to the parts store and see what ones fit,,,,, maybe the nonvented optis didnt come with orings on the shaft? what are the orings ment for?
Old Apr 14, 2007 | 01:56 AM
henryz28's Avatar
Ya mine is a vented opti.I have no Idea what they are for mabe to seal it in the hole.
Old Apr 14, 2007 | 08:35 AM
There are no o-rings on a non-vented opti.
Old Apr 14, 2007 | 03:58 PM
thanks henry...... and thanks shoebox for your anserw i dont need orings on the opticoil shaft!
Quickss96
Jan 29, 2016 05:56 PM
Ericksd
Jan 20, 2016 06:07 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
